nosoup4u
- 40C crawler
Post
by nosoup4u » Fri Jan 27, 2012 10:55 am
Can someone tell me if the rollers pictured here on a 350B need to be lubricated?
The OM shows them having a grease fitting but none of mine do. I can feel about a 1/4" hole in the bottom. Did every grease fitting fall out, or are these a different variety?
Post
by jtrichard » Fri Jan 27, 2012 11:37 am
no lube ......you have the sealed lifetime rollers .....your front and top idlers need lube and they take sae 140 gear oil
