Oil filter for a JD 440IDC
old dutchmen
Post by old dutchmen » Sun Apr 29, 2012 8:14 pm
The previous owner of my 440 diesel crawler removed the oil filtration system from the dozer and plugged the ports on the engine. Can some recommend an oil filter system that I could install on my dozer? Thanks.
shinnery
Post by shinnery » Sun Apr 29, 2012 9:28 pm
The 2-53 uses a bypass oil filtering system, not fullflow. I would think you could get one of the mounts used in automotive (hot rods) applications for a remote mounted filter and put a spin-on filter on it. Someone had a thread and pictures where he had made new lines out of copper tubing for the existing filter. It would be very simple to make them longer to run to a spin-on adapter mounted nearby.
Something like this is what I was thinking of
http://www.jegs.com/p/Derale/Derale-Rem ... 6/10002/-1
whiteclipse16
Post by whiteclipse16 » Mon Apr 30, 2012 7:26 am
This thread is what shinnery was talking about. It has the correct oil line routing and mounting.
http://www.jdcrawlers.com/messageboard/ ... php?t=6145
Be careful if you try to go original because there are two different kinds of mounts depending on your serial number. The linked thread shows the newer style.
If your wanting an original setup that is like the thread here is one:
http://www.ebay.com/itm/JOHN-DEERE-440- ... 1c2669d62b
Ben
Post by JD440ICD2006 » Mon Apr 30, 2012 7:29 am
old dutchmen,
Check on the Internet. These things would be in crawler junk yards. There folks all over the country that part these things out. It would be an item that is not in high demand, so I would not pay big money for it.
That way it would be original and not spoil the value should you ever want to sell it.
pop pop
Post by pop pop » Tue May 01, 2012 4:51 pm
might be able to help you out here, i replaced mine with a spin on ,, i'll look for the original.
old dutchmen
Post by old dutchmen » Tue May 01, 2012 7:20 pm
Thank you for all of the suggestions. This site has alot of good people trying to help solve problems.
