The recent topic on the 450c HLR has got me thinking a bit. My question is do you use the clutch when switching from forward to reverse? I typically do, it seems much less violent that way. I've done it both and it seems to work but there is a pretty sudden jerk if I don't use the clutch. I do not typically use the clutch for high to low switches.
So I guess I've got 2 questions:
1) Do others do this?
2) Is this bad?
Thanks,
Phillip
H-L-R question
H-L-R question
JD- 450C track loader
Serial #208336T
Serial #208336T
To answer your questions ... Yes and No.
I'm not sure about your "C" model but on my brothers D and E models they both have "Decelerators". We simply hit the Decel when shifting from forward to reverse or reverse to forward. It is okay to use the clutch pedal as it is largely a creeper mechanism anyway. At least the first stage of the clutch pedal travel is. The second half of the travel is what disengages the engine drive clutch for transmission shifting. That is, from one gear to the other. You don't need to clutch or decel when moving the HLR from high to low or Low to high.
Hope this helps and some of these other seasoned 450 operators may have other opinions in the way they do it.
jdemaris
Re: H-L-R question
There is nothing wrong with using the cluth pedal. That being said, when adjusted properly the HL-R is designed NOT to jerk when shifted, with no foot clutch, even at full throttle. Same goes for the F-R reverser in the 350s.77 Ford wrote: it seems to work but there is a pretty sudden jerk if I don't use the clutch. I do not typically use the clutch for high to low switches.
