40 c control valve
lynn kitts
40 c control valve
Post by lynn kitts » Sun Aug 12, 2012 9:08 am
:?: is it normal for blade to go down fast
Post by JD440ICD2006 » Sun Aug 12, 2012 9:45 am
What are the conditions?
Is the engine running or shut down?
Are you pushing the control valve to let it down?
JD40c
Post by JD40c » Tue Aug 14, 2012 1:50 pm
Is the control valve set up to float (it can be)? Are the piston seals on the hydraulic cylinders shot?
In my case, someone had put undersized o-rings on the pistons, so as you can guess, there was a huge internal leak.
1955 John Deere 40C 4-roller
