440 reverser
Howard Yoder
440 reverser
Post by Howard Yoder » Thu Oct 18, 2012 6:19 pm
My reverser went into reverse with about 10 pds. of pressure and went into foward with about 15 to 20. It seems that when I ajusted it it was either going to be a light 25pds or the next notch was close to 40 pds. I left them at close to 40 pds. the book recomends 25 to 35. Just curious if I should leave it where I have it or move it back a notch. Also does anybody have any good tips on getting all the hydrullic fluid out to change it.
Post by Lavoy » Thu Oct 18, 2012 8:10 pm
Howard,
Normally not that drastic a change for one detent. Is there some binding in the linkage or anything like that?
Howard Yoder
Post by Howard Yoder » Fri Oct 19, 2012 1:45 pm
no everything seems to work all right just don't want to do any damage or being to light and letting it slip I think it will be all right just where they where not getting a good snap. I think this is where a lot of reversers get ruined by not taking the truoble to ajust them till they go bad. I think I will run it for a while and see what happens,
Post by Lavoy » Sun Oct 21, 2012 5:16 pm
Check all the pivot points and pins for wear. I know in the past I had one that did not want to shift, and just reparing and adjusting on the linkage fixed the problem.
