Hi, I'm a newbe here and just picked up a pretty nice 1977 450c. It has one of the blade lift cylinders leaking, as the gland nut appears to be stripped. How do you go about removing the rear pin from the cylinder? Will it need drilled and tapped so that it can be pulled from the housing?
Dan.
450c Lift Cylinder Questions
