750 dozer neutral problem
goodnk
Post by goodnk » Tue Oct 30, 2012 2:27 pm
I have a '95 750BLT hyro trans. As soon as I release the trans lever the dozer starts moving forward with the trans shifter in neutral. I can't seem to figure it out. All linkage seems to be okay. If I pull the shifter back to reverse about .5 inch, dozer will stop. Thanks for any help.
Post by digitup2 » Tue Oct 30, 2012 3:41 pm
If that linkage gets wore out you can have problems centering it not only the linkage but also the shaft is a big problem neutralizing out can be a scary problem on the old Deere Hydro's they will wander off on there own so be careful !! don't leave it idle and not be in it .Digitup.
