radiator question
radiator question
well we took our radiator to get flushed and checked over, turned out if was way beyond repair. the guy said it had more holes than a screen door. we found a nice replacement out of a tractor, looked to be identical. well when we got it home we found the inlet and discharge on the new radiator are a larger diamater than what was in our crawler. will this work??
Home of the free because of the BRAVE!!!
1957 420 5 roller 5 speed
- Willyr
It will work. Just going to be awkward when you try to hook up the hoses.
former owner of a 1956 420c
Something is fishy, no difference between tractor and crawler. You must have gotten the radiator out of a different model.
I have new radiators if need be.
Yes, M and 40 use the same radiator, 420 and 440 use the same, 430 is different in the height of the neck, but it will bolt up.
Laovy
Laovy
