I would like to know the gpm flow of the hyd pump on my 1957 420.Going to make it power angle and I'm going to up grade orginal hyd valve to a new 2 spool valve.Lavoy, you propably know the answer to my question.Thanks
Cooter
420 hyd info
- 1954cooter
- 430 crawler
Re: 420 hyd info
The Service manual states 900-950 psi at 9 gpm. I purchased a standard high pressure directional control valve and plumbed a inline poppet pressure relieve valve before the valve body. Baileynet.com part number 222-785. I did all of this when I made a 3 way blade for my 420.
- 1954cooter
- 430 crawler
Most high pressure valves will only go down to 1500PSI or so.
