Hi folks, am trying to remove the right drive shaft and brake rotor to repair the inside oil seal. It and the brake rotor do not want to slide off, they are loose and shakes but doesn't want to come off. Is there a ring or some else that needs to be removed? Lent my book to the neighbour and haven't got it back yet.
https://picasaweb.google.com/1048922624 ... 9913672274
Thanks for your time.
Trying to remove shaft
Not sure exactly what you are working on, pic would not load for me. If you mean the brake drum/steering clutch assembly, that should have stayed with the final drive, not the crawler itself. If so, wiggle and pull or jerk, it will come out eventually.
Hi Lavoy,
No luck if you click the link? I thought we gave the pic "anyone with the link" status. Works for us but we're the owners.
Sorry for the poor terminology, our manual is inaccessible for the next few days.
We took off the track, then right side housing, now looking at the what appears to be the brake/clutch assembly with a shaft sticking out. When I checked the manual a couple months earlier it looked like it all just slid out if you tugged on the shaft. Have some help over the holidays and thought we'd give it a go.
New Year's eve and we're pulling apart a 420C, got to wonder about that.
Thanks.
Thanks.
Users browsing this forum: Google [Bot] and 160 guests
