Looking for a diesel priming pump for the 2010 dozer along with track chains and a track adjuster...Can anyone help me?
Thanks in advance!
2010 Dozer (diesel) Parts
For the primer pump, look to an aircraft supply source, Aircraft Spruce is one I think I have dealt with.
Chains might be tough now, I know a while back I could get them, not sure now.
Adjuster should be no problem, but is dependant on serial number.
Joe, here are some of the threads on this subject:
http://www.jdcrawlers.com/messageboard/ ... ght=spruce
If pre-42,000, be sure that the data plate looks original. Oftentimes the serial number plate on the block is missing or one from an ag tractor (green instead of yellow letter highlights) due to an engine swap.
