power beyond adapter
fwfedorak
Post by fwfedorak » Sun Apr 07, 2013 12:43 pm
I have a JD350 crawler with control stack that has Power beyond Valve and was wondering If the power beyond adapter fitting is still available to purchase ? Or will any fitting or hose fit valve stack ? standard thread ?
Post by jtrichard » Sun Apr 07, 2013 1:50 pm
power beyond is a special fitting JD might still have them
KenP
Post by KenP » Sun Apr 07, 2013 1:56 pm
deleted
fwfedorak
Adapter fitting
Post by fwfedorak » Sun Apr 07, 2013 2:44 pm
But wouldn't all the flow go to the end of the stack and out the port even if their was just a fitting attached as long as I didn't use controls for loader bucket or boom? I am confused how adapter fitting works.
KenP
Post by KenP » Sun Apr 07, 2013 4:20 pm
deleted
fwfedorak
power beyond
Post by fwfedorak » Sun Apr 07, 2013 4:41 pm
Okay, I think I understand it now. The power beyond adapter blocks the return flow in the internal valve body, That return channel now being blocked is the reason you have to connect the two attachment hoses together when not using attachment because that is your return route now. I believe this is correct? Now I just have to find Power beyond adapter somewhere.
KenP
Post by KenP » Sun Apr 07, 2013 4:54 pm
deleted
