jd 350 serial # confusion
jdsteel1123
I have a straight 350 and I'm a little confused about the serial numbering. I've read previous posts about the numbers but i don't know which apply to my tractor. T4F1D 058556T. I'd really appreciate some clarification beings how the dealership claims its a 1988 model but obviously its not.
i would guess its 67 look here http://www.jdcrawlers.com/messageboard/ ... mbers+year
I would agree with Richard on the year, based on the serial number (second part of data plate info). The first part of it is explained below- this was from a post on the 450 series, but you can see most of the codes are the same except the series (I believe "4" is for the 350 series) and the transmission (I'm guessing the "D" is a directional reverser):
Explanation of Type Codes per SM 2064
Basic Tractor Serial Number Explanation
1 2 3 4 5 6 7
T 5 F 3 M xxxxxx T
1. The first letter designates the application T = Tractor
2. This number designates the series 5 = JD450
3. This number designates tractor style C = Crawler, E = Crawler Loader, F = Crawler Dozer
4. This number designates the fuel type of the engine 1 = Gasoline, 3 = Diesel
5. This letter designates the type of transmission C = Collar Shift, M = Hi - Low Reverse
6. Sequence serial number of six digits Differs for each engine
7. This letter designates the manufacturer T = John Deere Dubuque
Tractor Works
1 2 3 4 5 6 7
T 5 F 3 M xxxxxx T
Tractor Works
