440 track adjuster
440 iron popper
440 track adjuster
Post by 440 iron popper » Fri Apr 26, 2013 6:46 pm
I have the older style track adjusters (threaded tube). One is stripped. I can't find the hydraulic adjuster part # for 440 in the book. What would be the best alternative? Change the broken tube and screw I find them... or upgrade to the hydraulic style. Where can I find parts for that at a decent cost?
Thanks,
Gil
Post by Gil » Fri Apr 26, 2013 8:35 pm
The JD440 hydraulic adjust is no longer available from Deere. The JD350 adjuster will work but looks a little different if you are looking for original restoration. There is an after-market hydraulic adjuster that is considerably cheaper and I have heard a number of people say they are very happy with them. Lavoy has sold them in the past and may be able to get one for you. Gil
Post by Lavoy » Sat Apr 27, 2013 6:32 pm
Really expensive to convert to the repacement adjuster from Deere, the aftermarket adjusters work just fine, about $350 last I knew, or I have some of the pieces for the mechanical adjusters done as well.
whiteclipse16
Post by whiteclipse16 » Sat Apr 27, 2013 8:53 pm
I'd convert to the hydraulic adjuster.
I'm pretty positive the 1010 uses the same adjuster so that will expand your search capability some.
Ben
440 iron popper
Post by 440 iron popper » Mon Apr 29, 2013 10:21 am
Thank you gentlemen.
Lavoy, do you have 2 in stock?
Post by Lavoy » Mon Apr 29, 2013 12:50 pm
I don't, but easy to get.
