#61 blade questions on a 40C
JD40c
Post by JD40c » Sun May 05, 2013 8:39 pm
Finally getting off my butt and putting the #61 blade on my 40C, replacing the #76 blade that was on it.
I have the full belly pan setup and it would seem that the long bar that goes from the front frame cross bar up to the front tow/pull lug gets in the way of the crossbar lift arm for the blade.
Can anyone confirm that the tow lug isn't compatible with the #61 blade?
There won't be much clearance for the front belly pan either, but I think it'll fit.
1955 John Deere 40C 4-roller
57jd420
Post by 57jd420 » Sun May 05, 2013 8:43 pm
look at my posts, theres one from a few weeks ago about the #61 blade. another member posted a link for a downloadable copy of the manual for the blade. hope this may help.
Home of the free because of the BRAVE!!!
1957 420 5 roller 5 speed
JD40c
Post by JD40c » Sun May 05, 2013 9:01 pm
I have the parts list already. It doesn't say anything about other parts on the crawler.
Post by Lavoy » Sun May 05, 2013 10:01 pm
Never thought of it til you mention it, but it does seem like it won't fit.
JD40c
Post by JD40c » Mon May 06, 2013 8:07 pm
Do you have the long heavy metal bar/strap that runs back to the front cross-bar though?
JD40c
Post by JD40c » Thu May 09, 2013 7:31 pm
Cool. Hopefully it'll fit the same for me. I'm waiting on a couple parts before bolting the blade frame to the crawler frame.
JD40c
Post by JD40c » Mon May 20, 2013 11:22 pm
Yep. The bar did indeed fit.
