1010 Bachhoe attachment
charlesflorence
Post by charlesflorence » Fri May 10, 2013 9:09 am
Will a 1010 backhoe attachment fit a 420C? :?:
cflorence
Post by jtrichard » Fri May 10, 2013 11:29 am
in the book they used the 50 and 51 on both the 440 and the 1010 looks like the mounting brackets are different on 440 vs 1010 if you have rear mounting bracket on your 440 it should go right on there or if you get the 1010 brackets if the bottom bolt area is the same you could make the top bracketing i would think .....go to jd parts online look at to parts book (PC619) pages 30 32 33 and you can see what some of the bracketing looks like ....hope this helps
charlesflorence
Post by charlesflorence » Fri May 10, 2013 11:46 am
that leads to the question does a 440 have the same backhoe mounting attachment points as a 420? Our local adds have a 1010 backhoe for sale and if it will fit i'd like to buy it.
cflorence
Post by jtrichard » Fri May 10, 2013 11:55 am
in the book it looks like 420 is way different than 440
charlesflorence
Post by charlesflorence » Fri May 10, 2013 12:30 pm
thanks then i'll pass on this one
cflorence
Post by Lavoy » Fri May 10, 2013 12:49 pm
420 is completely different as far as mounts, no interchangeability at all, in fact, I have never even seen the factory 420 mounts other than in a parts book.
Post by jtrichard » Fri May 10, 2013 5:10 pm
old timers must be setting in i had it in my head yours was 440 not 420 OOPS :? :oops:
