6 way
- gregjo1948
6 way
Did JD offer an all hydraulic 6 way blade on the 420C model? Thanks, gregjo1948
Re: 6 way
I'm not 100% sure but I don't think I seen any all hydraulic 6 way blades until the 350's came out. I would say custom made is the only option for a 420!gregjo1948 wrote:Did JD offer an all hydraulic 6 way blade on the 420C model? Thanks, gregjo1948
No, first factory Deere 6 way was on the 440. If fact I have heard that it was the first factory 6 way of any of the manufacturers.
- Paul Buhler
notmeu is being modest. Take a look at his.
http://www.jdcrawlers.com/messageboard/ ... php?t=7522
Willyr also fabricated a 6way blade as I remember and posted pictures of it.
OT: I noticed that my house keeping at Photobucket has caused a link problem. I'll try to fix it soon. Paul
- Willyr
Yes I did create a 6 way. I could do it again if some one wanted to pay for it.
https://www.youtube.com/watch?v=uz4sAynD2mo
some of the construction pics can be found here.
http://s88.photobucket.com/user/Downeas ... Deere/420c
By the way. I went through almost 50 pounds of 3/16" 6010 welding rod for the conversion.
former owner of a 1956 420c
Lavoy, Did the 440 come with a full hydraulic 6 way or did it have the manual pins? Just curious, I never seen one. Willy I know what your talking about, I went thru a good 40 pounds of .035 wire building mine!Lavoy wrote:No, first factory Deere 6 way was on the 440. If fact I have heard that it was the first factory 6 way of any of the manufacturers.
Re: 6 way
FYI, my 2010 dozer has a factory 6-way hydraulic blade (model just after the 440 but before the straight 350/450).notmeu wrote:I'm not 100% sure but I don't think I seen any all hydraulic 6 way blades until the 350's came out. I would say custom made is the only option for a 420!gregjo1948 wrote:Did JD offer an all hydraulic 6 way blade on the 420C model? Thanks, gregjo1948
Yes, model 64 hyd 6 way blade. Manual 6 way blade was the model 63.
Re: 6 way
Well gregjo1948, to answer your question it sounds like a no to me! That is, not a factory option! Unless you get that welder out!!!!gregjo1948 wrote:Did JD offer an all hydraulic 6 way blade on the 420C model? Thanks, gregjo1948
- gregjo1948
6 way
Next ? Would an all hydraulic 6 way from an early 440 fit to a 420 without fabrication? Thanks, gregjo1948
Re: 6 way
I can't speak for how a 440 6-way would mount up to a 420 but I would think there would be a little fabrication. For example when I made the 6 way on my 420 I had to get every ounce of fluid out of my existing hydraulic tank that I could so I did not run short, So I installed a 10" extension pipe onto my filler tube so I could get a little more fluid into the tank. It worked out great, except for when I would climb a steep hillside or do more of a pushing the limits of gravity move I would get some fluid coming out of the filler tube. But I would think a 440 tank would be bigger and it was probably in a different location than the 420????gregjo1948 wrote:Next ? Would an all hydraulic 6 way from an early 440 fit to a 420 without fabrication? Thanks, gregjo1948
Mounts are completely different, major fab work to say the least. No place to mount the rub blocks is another problem.
- Willyr
If you haul it to Maine I would be more than happy to make the conversion for you. I still have some of the 3" od 1" id structural tubing left over.
I need something to do, so if you didnt mind some one else working on it for 6 months, it wouldnt be a prob for me. I can deliver yet I get 50 cents a mile.
- gregjo1948
6 way
Lavoy-- I think the Internaional T340/ TD340 might have had a fully hydraulic 6 way. They came out about '58 '59 and would have been about the same time as JD 440. Whom do suppose stole the idea? Maybe the 310 Case.
gregjo1948
