Two stroke diesel trouble
ckutz1985
Post by ckutz1985 » Tue Jul 09, 2013 5:42 pm
My 440 loader has the Detroit two stroke diesel in it and the other day I noticed I started to loose power. The next day I could not get it to stay running . It would start up very easy and run for about 6 seconds and then die again. After about 20 times of trying it would finally stay running but would run rough. It would not seem to get to full rpms. It would keep revving up ans down on its own. The next day it would do the same thing. It seems like as soon as it would start to warm up it would stay running but not that good. I cleaned out my fuel lines and replaced my fuel filter. And it still does it.could it be my fuel pump? I noticed a little bit of diesel was leaking between my fuel pump and my engine but it was just a drop or two.
gregjo1948
two stroke diesel trouble
Post by gregjo1948 » Wed Jul 10, 2013 6:26 am
How's your air intake? Blockage of air could be a problem. Isn't there a blower on your Detroit diesel? I'm quite sure there is on the larger Detroits. gregjo1948
Post by Lavoy » Wed Jul 10, 2013 8:45 am
I had trouble with the line between the fuel filter and the fuel pump collapsing.
DukeofDeere
Post by DukeofDeere » Thu Jul 11, 2013 9:22 am
Could be loaded filters.
Duke
ckutz1985
Post by ckutz1985 » Fri Jul 12, 2013 9:01 pm
I replaced all the fuel lines and put a brew filter on it and a new air filter and it still does it
Post by Lavoy » Sat Jul 13, 2013 8:13 am
How did you put a new air filter on it, they are an oil bath filter?
ckutz1985
Post by ckutz1985 » Sat Jul 13, 2013 8:16 am
Mine had a generic foam filter above the oil bath. I've tried it with and without
ckutz1985
Post by ckutz1985 » Sat Jul 13, 2013 8:28 am
I know it does not belong there but it worked fine there for over a year so I kinda like the extra protection
DukeofDeere
Post by DukeofDeere » Sat Jul 13, 2013 8:38 am
Check the bottom of your tank for debris over the fuel hole.
Duke
ckutz1985
Post by ckutz1985 » Sat Jul 13, 2013 8:39 am
I'll go do that right now
ckutz1985
Post by ckutz1985 » Sat Jul 13, 2013 9:51 am
Just checked it and its ckean
DukeofDeere
Post by DukeofDeere » Sat Jul 13, 2013 5:42 pm
Bad fuel?
ckutz1985
Post by ckutz1985 » Sat Jul 13, 2013 5:44 pm
I just drained it all and put new in and it still does it. Could it have anything to do with my governor maybe?
Post by Lavoy » Sat Jul 13, 2013 6:33 pm
not likely, still sounds like a fuel problem.
DukeofDeere
Post by DukeofDeere » Sat Jul 13, 2013 8:04 pm
May have to track fuel flow starting at the tank and work your way down.
Take loose at each connection.
Duke
