450c crawler...return hydraulic filter
firedog7007
Post by firedog7007 » Mon Jul 29, 2013 1:03 pm
Does anyone know the location of the return inline hydraulic filter on a 1976 450c crawler. The information I have indicates near the hyd. fluid tank. Its not there. I have traced the hyd. lines to the skid plate. I have yet to find it. some people say there are 2 of them. some also say under the skid plate. needing some help here guys. :roll:
77 Ford
Post by 77 Ford » Wed Jul 31, 2013 7:06 am
Mine was in the tank, at first I didnt think so but once I drained the tank I found it all laying in the bottom of the tank.
Might try fishing around in the bottom.
JD- 450C track loader
Serial #208336T
DrLoch
Post by DrLoch » Thu Aug 01, 2013 6:37 am
Interesting question, I was going to ask the same thing at some point in time. The manual, at least mine, shows it on top of the reservoir which mine is not. I'm going to drain the tank and add a different sight gauge with a thermometer. My oil level was low but you really couldn't tell by looking at the existing sight gauge. Ended up removing a pipe plug on top and using the fuel level dip stick to determine it was low.
450C Track Loader
291457T
Scottyb
Post by Scottyb » Thu Aug 01, 2013 7:28 am
The sight gauges work well if they are cleaned up. Pull it apart and tidy up the inside and you will have no problem seeing the level.
backhoe attachment.
firedog7007
Post by firedog7007 » Thu Aug 01, 2013 8:00 am
Scottyb wrote:The sight gauges work well if they are cleaned up. Pull it apart and tidy up the inside and you will have no problem seeing the level.
I have found the filter in the hydraulic tank. It was loose about a 1/2 inch. I pulled and cleaned it. I'm trying to find the "in Line " filter. My hydraulics slowly closed down. no power to any controls or buckets, or backhoe operations. I'm thinking the In-line maybe clogged. I just can't find the damn thing :oops: anybody no where it is? :roll:
DrLoch I pulled the fill top where I found that filter. They also said it may have a micro filter at the bottom of the tank. mine didn't have a micro filter, just a pipe.
DrLoch
Post by DrLoch » Fri Aug 02, 2013 7:14 am
From the sounds of it your problem isn't with the return line filter. Generally a return filter is a low pressure filter like the oil and transmission filters. They aren't designed to pressurized much over 250 PSI if that. To cause what you are seeing would mean it is totally block which would cause a major restriction and would likely blow the filter off or cause a major leak at the gasket area. I design and built hydraulic systems for a living and I can assure you if the inline return line filter, if you have one, were the issue you would have found where it WAS mounted given the issue you are seeing. Just follow the return/tank line off the valve bank which is in that same area, if tank line goes from the valve bank to the reservoir then you don't have a return filter, which would be the same as my machine.
450C Track Loader
291457T
JD430C
Post by JD430C » Fri Aug 02, 2013 7:48 am
I am pretty sure there is no inline filters on the 450Cs. Early 450Cs had the filter in the tank, later ones had a spin on filter on top of the tank. I am guessing you either have a collapsed line or a clog between the tank and pump.
Post by digitup2 » Sat Aug 03, 2013 6:46 am
Some were made with a return filter and some never had one .Loaders were a different ball game again .I think it depended on who built the crawler that day and what day it was built so if it was built on a UAW calender f$^k it friday that was how it was built .Digitup.
