worn out rails
jsal
worn out rails
Post by jsal » Tue Jul 30, 2013 5:33 am
I am having problems with the track coming off the sprocket 3 times so far.I am thinking chains are worn beyond use . anyone know of a good place to buy new I am in Michigan.
JIM
Post by Tigerhaze » Tue Jul 30, 2013 8:53 am
I would recommend that you search this board for posts about undercarriage- they generally wear as a set and replacing the tracks (although a likely issue) may not entirely fix your problem. I am assuming that you have properly tensioned the tracks, which can be another cause of derailing.
There are some inspection guides posted so you can measure pin and bushing wear, rail height, inspect rollers, idlers and sprockets, and observe alignment. For instance, you won't want to install new tracks only to have them wear prematurely because your sprockets are worn down.
BTW, you didn't mention what model crawler you own as that will dictate the type of tracks you need (dry or SALT) and availability of them.
Here are a few of the threads that will be useful:
Undercarriage Vendors (the question you directly asked)
http://www.jdcrawlers.com/messageboard/ ... ercarriage
Undercarriage Wear Gauges (Depends on Model of Crawler You Have)
Undercarriage Inspection
jsal
thank you
Post by jsal » Tue Jul 30, 2013 9:30 am
thanks much
I will check things a bit more.
JIM
77 Ford
Post by 77 Ford » Wed Jul 31, 2013 7:08 am
You could also post up pictures of your UC and people can look at it and tell you quite a bit. They found that my recoil springs were broken, causing my track tension to be wrong. Replaced the springs and I've not thrown a track sense.
JD- 450C track loader
Serial #208336T
jsal
Post by jsal » Fri Aug 02, 2013 5:37 am
Measured my tracks to see how worn they were 100% worn 23.57" mine measure 24.25" no wonder they jumping the sprocket my grossers are only11/16 high was going to weld new grouser bar this winter. New rails and pads are ordered.ITR America $2860.00 $150.00 Shipping.
jsal
Just My Luck !
Post by jsal » Sat Aug 10, 2013 1:35 pm
Bought new set of rails and pads installed one side all went well was putting together second getting ready to install master pin and noticed an excessive amount of slack under front idler counted pads I was was sent one track with 36 links and one with 39 links .now i have to wait to contact who I bought them from.
Post by jtrichard » Sat Aug 10, 2013 6:26 pm
sounds like you have a 350 (you have never said) 36 is 350 ...39 links is 2010.... if they are standard chains/master pins take a torch and cut off three links (just make sure you do the correct end ..best way to describe that is the male end) edit ..i just looked at your other posts and i see you have a 350 the one chain they sent you is for a 2010 ...same links just three more of them
