AllenS
- 430 crawler
Post
by AllenS » Sat Aug 03, 2013 12:02 pm
Sometimes when I pull back on the left steering lever, it wants to slow down the crawler, instead of locking up that side to turn. Especially noticeable when going up a hill. Something must be too tight, but what?
Post
by jtrichard » Sat Aug 03, 2013 4:11 pm
sounds like your left clutch may not be releasing (no fingers? no bearing?oil swelling the fibers?)
gregjo1948
Post
by gregjo1948 » Sun Aug 04, 2013 5:18 am
Maybe it's the left brake band not gripping, but the clutch is releasing.What does "slow down the dozer" mean? Is the machine movement deceasing or are the engine rpms decreasing? gregjo1948
AllenS
- 430 crawler
Post
by AllenS » Sun Aug 04, 2013 7:29 am
Slow down the dozer means that when going up a hill and I pull on the left steering lever the machine will come to a stop. By the way, this is a 40C. When I first start using it, everything seems ok, but after an hour or two is when there is a problem.
gregjo1948
Post
by gregjo1948 » Sun Aug 04, 2013 7:55 am
Sounds like the problem is your right side clutch is slipping. Might be in need of adjustment or may be too worn discs or possibly oil has leaked on it from a bad seal. gregjo1948
Post
by jtrichard » Sun Aug 04, 2013 4:15 pm
i took slow down as the engine speed .... from what you have now said yes your right clutch is slipping... see if you have any free play on the throw out bearing
AllenS
- 430 crawler
Post
by AllenS » Sun Aug 04, 2013 4:19 pm
Will check out helpful hints. Probably will have more questions, but...
Thanks.
Users browsing this forum: No registered users and 59 guests
