Thanks in an advance for any help. This forum has been a ton of help for my newly acquired dozer and I.
My 6 way blade control is leaking from the control spools on top of the module. Is there a way to rebuild (replace O-rings and packings) these on this module? I have a background with aircraft hydraulics and it looks to be of similar construction.
Can someone point me towards part numbers of the O-rings or a kit if that sort of thing is available?
Thanks,
Mid 70's 450C blade control valve rebuild
here is one of the valves they used on 450c http://jdpc.deere.com/jdpc/servlet/com. ... ervlet_Alt T28004 is the seal you need X6
When I did mine on my 350 my valve and pump were Cessena I found a pump kit online and bought it from an aircraft repair garage for the valve seals I used with a place called Martin fluid power they are all over the US not sure if they are in AK.If you have a parts book JD most likely should be able to get them .
