looking for pto shaft 450c
I'm looking at buying a 450c that's nearby but in order to make good use of it it needs pto. Anyone know where I might get a used one?
PTO Shaft
If you want to do PTO work, the crawler needs to be equipped with the PTO drive option. I have never seen one in a 450. I guessing there should be an engagement lever for the PTO on top of the HLR as that is where you'd find the lever on a 350.
They are all capable of accepting a winch drive shaft but a winch drive is only suitable for running a winch.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Willen, the PTO on crawlers does not run at same speed as PTO on tractors and is mainly meant for running winches. It's not to say it can't be done (Gus on here did it with a 420 crawler) but generally isn't in sync. Take a look at these threads:
http://www.jdcrawlers.com/messageboard/ ... hlight=pto
Here was Gus's thread on mowing with a 420:
http://www.jdcrawlers.com/messageboard/ ... ight=mower
Users browsing this forum: No registered users and 133 guests
