hello all,
i have a 40 crawler, it would not start, it had no spark to the dist. i bought a kit with cap, rotor, wires, points, cond. and plugs. no it will start but only runs at idle for 30 seconds. then it will start again and run for 30 seconds.
fresh gas, new batt. and coil. any ideas?
thanks
1955 40c
- DukeofDeere
- Paul Buhler
After checking for good fuel flow to the carburetor as mentioned, if not resolved, the problem could be a sticking float in the carb. Try gently tapping on the side of the float bowl with a soft hammer or screwdriver handle and see if there is any change. Sometimes this all that's needed. I'd still remove the carb and disassemble and clean it up it at some point, installing a rebuild kit for peace of mind. This is not a very difficult task. Good luck.Paul
