450c crawler
David Rigsby
450c crawler
Post by David Rigsby » Sat Jan 11, 2014 9:16 pm
What do you guys use to remove the starter bolts/nuts on this dozer. I cannot use a swivel head socket due to tight fit between housing and nuts. You know it is a tight fit and before buying all kinds extensions or sockets, I thought you guys could help me
DukeofDeere
Post by DukeofDeere » Sun Jan 12, 2014 6:22 am
Deere has a special wrench to use to reach these bolts.
Duke
David Rigsby
John Deere Starter Wrench
Post by David Rigsby » Sun Jan 12, 2014 7:48 am
Thanks for the reply. Now, do any of you have the starter wrench you would sell? Price? Thanks David
Post by jtrichard » Sun Jan 12, 2014 11:37 am
Post by Lavoy » Sun Jan 12, 2014 12:18 pm
Check with a Snap-On dealer if you have one locally. The Deere part number listed there can be ordered by your dealer through their special tools ordering system.
David Rigsby
Wrench
Post by David Rigsby » Sun Jan 12, 2014 12:40 pm
Thanks very much. Just thought I would remove and have rebuilt because it is beginning to drag some while starting. Thanks again...
Post by Lavoy » Sun Jan 12, 2014 4:43 pm
Couple other thoughts. A chrome swivel socket is a lot smaller diameter than an impact if that is what you are using.
Can you get a straight enough shot to use a wobble extension? Not a lot of degrees of angle, but they have saved my butt in the past.
David Rigsby
wrench
Post by David Rigsby » Sun Jan 12, 2014 4:52 pm
I was able to find the JD wrench for $30 bucks so I ordered for less trouble. I did try swivel heads etc. but was unable to get anything to fit on with any of the sockets without grinding it down. Thanks This has been very helpful...
Paul45
Post by Paul45 » Tue Jan 14, 2014 12:27 pm
I have used a 12 point close end wrench. You can only get about a 1/16 turn LOL I sprayed it down good with WD40 and clean off threads good so i can use my fingers as soon as possible. Good luck!!
thanks Paul
350 track loader, 350 dozer
