1010c
1010c
1010c
Post by 1010c » Sun Jan 19, 2014 10:53 am
On my 1010c the hydralic adjustor is stuck on the left side. can I pull the button head fitting out without the spring flying out? Also how does the lights in the dash come out I need to replace them ?
Post by Lavoy » Sun Jan 19, 2014 10:56 am
Yes, no spring, go ahead.
Probably easiest way is to pull the dash so you can see both sides of the receptacle.
1010c
thanks
Post by 1010c » Sun Jan 19, 2014 11:06 am
Thank you for your reply. Are the bulbs in the dash just normal bulbs ao are they a sealed unit?
Post by Lavoy » Sun Jan 19, 2014 4:09 pm
Don't know the number, but just a small single terminal bulb.
