1010c tesioner
1010c
1010c tesioner
Post by 1010c » Sun Jan 19, 2014 8:37 pm
Can I take the bolts that connect the front idler to the hydralic tesioner without the spring in the rear comming off?
Gil
Post by Gil » Sun Jan 19, 2014 11:17 pm
Those large springs are only under tension when the track is stressed extremely tight. For example, if you crawl over a large rock, or if the track is packed with mud. If you have any slack in your track you can remove the front idler bolts and the spring will not move. Gil
1010c
Thank You
Post by 1010c » Mon Jan 20, 2014 9:44 am
Thank you very much for this information . Also does any one have a part number for the seal kit for the original tesioners?
Post by Lavoy » Mon Jan 20, 2014 2:51 pm
There is no kit number, only individual parts on the original style. There is also an update that may have been performed, so you will need to take the piston out to see what style you have.
1010c
Thank you
Post by 1010c » Tue Jan 21, 2014 10:48 am
also are these available from a dealer?
Post by Lavoy » Tue Jan 21, 2014 12:59 pm
They should be, but you never know with some dealers.
Laovy
