transmission to reverser bolts JD350
RE; JD350. Just inspecting new to me 1970 JD350. FOUND ALL FOUR TRANSMISSION TO REVERSER BOLTS ARE BROKEN OR STRIPPED! AS ENGINE AND TRANSMISSION ARE BOTH BOLTED SOLID TO FRAME I CANNOT IMAGINE HOW THIS HAPPENED. ANY ONE HAD THIS PROBLEM?
If you search the archived discussions on this board about 350s, I believe this is mentioned as something to look out for prior to purchasing a used 350. Those threads also have some good advice about how to repair them if you need some information.
Users browsing this forum: No registered users and 90 guests
