420 C Oil Pump
dkokai76
420 C Oil Pump
Post by dkokai76 » Tue Mar 18, 2014 5:52 pm
Im looking for a new oil pump for my 420 and not having any luck finding one. Looking for help.
Post by Lavoy » Tue Mar 18, 2014 7:11 pm
Hyd pump, engine oil pump?
dkokai76
Post by dkokai76 » Tue Mar 18, 2014 7:13 pm
Engine oil pump
Post by Lavoy » Wed Mar 19, 2014 6:34 am
New pumps have not been available in probably 20 years other than if you find an NOS one. Only thing out there is going to be used.
vtjoe
your pump
Post by vtjoe » Wed Mar 19, 2014 6:35 am
what is wrong with yours?
dkokai76
Post by dkokai76 » Wed Mar 19, 2014 1:09 pm
A few months ago I had no oil pressure and the roll pin on the drive gear had snapped off. I fixed that and everything was fine. A few weeks ago I needed my baby to plow snow and no oil pressure again. I cant imagine whats going on but I just wanted to buy a new pump install it and be done. Now I don't know what to do if they don't make them any more. Do they sell a rebuild kit for the engine oil pump???? Ive seen used ones on Ebay but who knows what your getting!!!! Any advice????
1958?? 420 C 5 Roller
1980 350 C
Post by Lavoy » Wed Mar 19, 2014 9:04 pm
No kits, no parts. Take yours apart and see what you find. Sheared pin is usually ice.
dkokai76
Post by dkokai76 » Wed Mar 19, 2014 11:25 pm
Exactly!!! The first time was ice. Took it all apart cleaned everything fresh oil and it was fine. Machine sat for about 2 months it had no trace of ice but had no pressure. I found a few pumps on ebay that look the same but they are listed for different machines. Are the pumps the same in all those earlier machines???
1980 350 C
Post by Lavoy » Thu Mar 20, 2014 8:11 pm
Something else might be up, new pin should have fixed the problem. I would make sure of the problem before buying a different pump.
dkokai76
Post by dkokai76 » Thu Mar 20, 2014 8:44 pm
We put new engine bearings about two years ago. I don't know what else to be looking for. Any suggestions?????
1980 350 C
Post by Lavoy » Thu Mar 20, 2014 8:50 pm
Do you know the pump quit again? If not, check the pump again to be sure.
dkokai76
Post by dkokai76 » Thu Mar 20, 2014 8:57 pm
I didn't take it apart yet. My last visit to the mountain it was 0 degrees!!!! I was not laying in the snow and dropping the pan. I unscrewed the gauge and just a little oil came out. I don't know what else it can because there isn't much to the system. Next year it will be parked inside the garage rather than next to it!!!!!
1980 350 C
