What synthetic oil to use (what grade)
What synthetic weight should I use for the 420 oil, transmission, and the finals?
If man can break it man can fix it .. it just takes time and money.
75W-90 or 75W-140 Mobil SHC is what I use.
0W-30 or one of the other Mobil 1's.
Re: oil
I run any synthetic DIESEL oil. They have a higher zinc content and Help with flat tappet cams.vtjoe wrote:what about the engine oil?
If you rebuild any flat tappet cam, make sure the oil you break it in with has the zinc so the cam won't wear out too fast.
Oil is cheap, engine parts aren't
1950 mc crawling around
