350 Hydraulic Hose
- Contact:
350 Hydraulic Hose
Where is the main pressure hydraulic hose from the pump to the valve body for the 6-way blade supposed to run?
I know mine is not run correctly as it runs across the top of the transmission and that holds the floor plate up so my steering clutch adjustment is wrong... mine comes from the pump down the right side, over the transmission the a big loop under the seat to the valve body.
JT
JT
Yep, always a challenge trying to figure out what someone else has cobbled together. Not sure if the jdparts website is as nice for 350's but love looking at the diagrams of various assemblies- helps kinda figure out how it's supposed to go.
http://m.jdpc.deere.com/jdpc/servlet/co ... ervlet_Alt
- Contact:
Thanks for the reply.
Sometimes the JD parts catalog does help, I can't even find the hydraulic pump for the 350 or the main hydraulic lines.
Also the only URL that works is the base http://jdpc.deere.com because the site is java or something you can't paste a page that you looked up.
I did look up the throttle cable the other day and priced it at $78 so I got out some cable lube and went to work on mine and got it loosened up and working better.
JT
JT
Those repair jobs are NOW to be known as PRESIDENTIAL SOLUTIONS.
Parts book for blade
If you go to JD parts web site enter 6305 in model search it will get you to the parts brake down for your 350 dozer or check out E Bay for a paper copy. the lines were steel and ran in the right side originally .looked on E Bay
2 available around 20.00.
Good luck JIM
Good luck JIM
Users browsing this forum: No registered users and 69 guests
