Looking for part #T13707T (brake spring) for my 2010 crawler transmission brake and shift valve linkage. Does anybody know where i might find one? No longer available from John Deere. My clutch pedal froze up over the winter. Pulled the engine and found huge mouse nest at the bottom of the clutch housing. Rusted the shaft at the bottom of the housing bad. while I was cleaning up that mess I found this spring was broken also. I need it to make the connection to the shift valve.
thanks
need 2010 crawler part #T13707T
deere201018013
if you cant get that you can most likely match it up at mc master http://www.mcmaster.com/#extension-springs/=rqnga3
deere201018013
