1010 gas starter wiring
Steelburner
Post by Steelburner » Tue May 06, 2014 8:19 am
Hello everyone!
I had to rebuild the starter on my 1010 gasoline crawler loader and the masking tape label on the wire fell off. I can't remember if the wire goes to the "s" terminal or the "r" terminal. Does something attach to the opposite terminal then?
Thanks!
Late model 1010 crawler loader
Post by jtrichard » Tue May 06, 2014 5:24 pm
wire goes to S ter. that is for start..........R is for hot start on a chevy
Steelburner
Post by Steelburner » Tue May 06, 2014 7:26 pm
Thanks jtrichard. What is a hot start? Is that like jumping the relay with a screwdriver?
Post by jtrichard » Tue May 06, 2014 10:36 pm
no HOT START is for cars/trucks with coil/points that have an external resistor on the coil ......when your cranking it throws full 12 volts to the coil bypassing the resistor which drops the voltage to 6 volts to the coil when running..... you can put hot start on any gas engine that has a coil/points and a resistor so it starts much easier when cold it doubles the spark
