I have a straight 450 loader with a problem. At first startup I drove it about 200 yards in forward and stopped to select a lower gear. When I shifted the reverser back into forward it wouldn’t move. I tried reverse with no luck. I shut it down, checked the oil level “GOOD” and walked back to the shop. I came back about 20 minutes later with a tractor to pull it back but decided to see if it would move on its own. I started it and shifted to forward, pulled the right steering lever and it turned so I headed back to the shop. When I went from forward to reverse to back into the shop it wouldn’t move again. I tried forward and it still wouldn’t move. I shut down again and walked out to get the tractor. When I got back I started the loader, put it in reverse and it back into the shop.
I put a pressure gauge on the accumulator to check the output pressure. The pressure came up to 150 almost instantly then started bouncing between 150 and pegging the gauge after about 10 seconds. In about 60 seconds the pressure started dropping, still bouncing, and finally dropped to a steady 10 lbs.
I pulled the pressure valve out and checked for binding or any kind of gunk but it looked clean.
I’m not sure where to look next any suggestions?
Straight 450 reverser problem?
Read these threads about your HLR transmission- you should have three pressure readings for Low, High, and Reverse. Your service manual describes the pressure testing and troubleshooting procedures:
http://www.jdcrawlers.com/messageboard/ ... +pressures
http://www.jdcrawlers.com/messageboard/ ... lr+testing
Thanks for the reply Tigerhaze. Here is a thread that I started when I had a transmission oil leak. The last page is where I am now but it’s still not working properly. I bought a new transmission line and replaced the cracked and brazed one. That didn’t help. I still have the buzzing noise and I’m thinking it may be a pressure valve. The transmission pump could be sucking air also. This buzzing noise was not there before I started taking things apart. Any ideas?
http://www.jdcrawlers.com/messageboard/ ... highlight=
Users browsing this forum: No registered users and 171 guests
