re..pre 42000 jd2010..cyl liner specs
dtoots1
Post by dtoots1 » Fri May 23, 2014 11:46 am
dear john....etc etc
book claims orig liner bore is 3.875 to 3.876 in
here is what i have on this one...listed 1 thru 4 cyls
3/8 below top..3.622 3.625 3.619 3.618
3.5 below top 3.619 3.618 3.623 3.609
midway.........3.609 3.627 3.629 3.6115
lengthways of liner
3/8 below top 3.621 3.621 3.62 3.619
3.5 below top 3.599 3.619 3.621 3.610
midway 3.6155 3.629 3.629 3.6035
book says if off 0.010 on any dims...need to replace liner and pistons..
is this in need or/and how long would normal use last???....is not runnning construction etc...has xmas tree farm
still cant figure out that original liner bore being larger than what the current dims are what gives????
thanks
dtoots1
Post by jtrichard » Fri May 23, 2014 5:00 pm
3.875 is DIESEL yours is gas (smaller bore)the specs are 3.625/3.626....max wear is 3.635/3.636..... looks like your inside mics are off ..have you checked the inside mics with some outside mics? main places to check are very bottom of cylinder and in the top ring wear area about 3/8 to 1/2" down from top that will tell you how much taper/wear you have
