leaking dozer blade cylinde
tony hammes
Post by tony hammes » Fri May 23, 2014 3:32 pm
I'm having trouble with the right side hydralic blade lift cylinder on my 52 mc leaking fluis. I took the inside cap off and put a peiceof leather in to tighten it up. It was leaking on the inside and now is leaking out both sides. Any kits made for the lift cylinder? Thanks
1010c
Post by 1010c » Fri May 23, 2014 7:14 pm
Your local hydralic repair shop will probally beable to find seals to fit the cylinder.
tony hammes
Post by tony hammes » Tue Jun 10, 2014 1:42 pm
I have the integral lift cylinders inside of the tracks. Do u think i can get a kit locally or should i try Levon?
Post by Lavoy » Wed Jun 11, 2014 10:12 am
Integral cylinders are all O-rings. Pull the lift shaft and put in all new O-rings and backups, put an extra backup on the inside side of the cylinder. Be careful to get the lift shaft indexed correctly when you put it back together.
tony hammes
Post by tony hammes » Thu Jun 12, 2014 3:20 pm
Thanks for your help Lavoy. The steering clutch kits u sold me a few years ago worked famously. I'm very happy with them.
Post by Lavoy » Fri Jun 13, 2014 9:10 am
No problem, glad to hear it.
tony hammes
Post by tony hammes » Fri Jun 27, 2014 6:03 pm
What is a backup and where do I get them?
Post by Lavoy » Fri Jun 27, 2014 9:18 pm
Any good hyd shop should have them along with the O-rings.
