430 engine
tractornutjd
430 engine
Post by tractornutjd » Mon Jun 30, 2014 8:02 am
Hi I have a 430 engine that knocks intermittently. It start and runs fine otherwise. Good oil pressure. My question can a governor weight be hitting the block? Noise usally show up at high rpm and it does not matter if the engine is loaded. Knock comes and goes. Any rhoughts before I tear it down?? P.S. sorry it is in a wheel tractor-430S . Would like to find a 430 dozer though!
DukeofDeere
Post by DukeofDeere » Mon Jun 30, 2014 2:24 pm
Try to determine where the knock is from.
Mechanics trick of using a long screwdriver tip against the block and your ear on Tue other end may help get you close to the knock.
Duke
Post by Lavoy » Mon Jun 30, 2014 3:31 pm
They won't hit the block, but will peel lots of tooth off of the cam gear.
