compression test 0n pre 42000 jd2010
dtoots1
Post by dtoots1 » Tue Aug 12, 2014 1:42 pm
have compression at 95 95 105 and 110 1 thru 4...books calls for 125
should this start with this compression? or will i have to do bottom end cyls etc ...ie...do i need at least 125 psi to detonate???
is gas job
thanks
dtoots1
Post by Lavoy » Tue Aug 12, 2014 2:12 pm
No, used to claim you need in the 50PSI range to fire, yours will definitely start on those numbers.
