Is it easier to pull the entire blade to remove the engine and change the isolation dampener, or can it be worked around to do the job??...2017 hrs...is there anything else that should be done while apart. Just bought it and put a pretty good 6 hrs of load on it and the reverser and hydraulics work perfectly. THANKS IN ADVANCE!!
---also - is it common for the crawler to sound much louder in reverse than forward(gear whine)
pulling the eng. on a 350c
Users browsing this forum: No registered users and 70 guests
