2 53 detroit startimg procedure
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sun Nov 23, 2014 7:45 am
Im working on my first diesel crawler and am wondering what position to put the throttle in for starting.
Thanks Ron
nothing crawles like a deere
whiteclipse16
Post by whiteclipse16 » Mon Nov 24, 2014 7:04 am
I don't know that there's any specific position because it's probably different for each crawler.
I put mine at about 1/4 to 3/8 throttle. It will more than likely hit on one cylinder for a few seconds then the second one will come in.
If it hits on one cylinder for a good while, give it a little more throttle.
If it kind of dies out/ chokes itself out use less throttle. I've noticed if I have to much throttle on mine (when starting of course) it seems to kind of flood out and die.
Ben
gregjo1948
Post by gregjo1948 » Mon Nov 24, 2014 7:28 am
1/4 throttle should work and in cold weather you'll probably need starting fluid. If the engine is really tired, you may want to use a bit of fluid in warm weather. gregjo1948
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Mon Nov 24, 2014 8:07 am
I figured about 1/4 throttle.
Just want to avoid unnecessary cranking.
original possum
Post by original possum » Tue Nov 25, 2014 11:35 am
Start at idle. Any throttle at all will be translated to full throttle by the governor. Starting with excess fuel will wash the oil from cylinder walls. Not good. It should hit on all cylinders. Don't goose it until you see good oil pressure.
DukeofDeere
Post by DukeofDeere » Fri Dec 26, 2014 6:51 pm
The JD operators manual says move the throttle lever to full throttle and then back to 1/2 then start the engine.
Duke
