2010 loader (820) question
- vailvalley59
- 430 crawler
Should the oil level for the 820 loader be checked when the motor is running or when it is stopped? I do not have any operator's manual for this--thanks
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
Two observations on my part:
-If not running, it is a little easier to check exact level on dipstick as when running you get some splashing effects
-When running, it is easier to tell if you have water in the fluid as it will turn it into a frothy milky color. If you check when cold and not running, the water separates from the oil and is not as easy to see.
