350C power reverser
350C power reverser
Hello, does anyone know a source for a complete power reverser for a 350C. Mine is weak and maybe the solution is to replace a complete unit rather than rebuild. Thanks.
JD 450C
JD 350C
IH 584
Ford 1300
MM 707
MF 95
JD 350C
IH 584
Ford 1300
MM 707
MF 95
350C
Dear sir I have a complete reverser if needed.. Also there should be a tag by the starter. a little aluminum tag.. the first numbers should identify your motor.. should say 3-164 or 3-179 etc.
the 350c has a different reverser than a standard 350 or 350B model,, I would also have the major components if you should decide to rebuild it yourself,, good luck.. Mark 8002-279-1888
JWB Contracting
Reverser Rebuild
Sorry about the high price here in west central Alberta but getting a good 350C case is difficult. The one I have available is in a working machine., I paid good money for this machine at auction in case w needed parts for our working tractors. I'm also working a deal for a widepad 350C with a cracked case.
You have to pull your machine down anyways. You might find yours isn't that bad and just needs a gear, bearings and seals.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
