MC crawler engine block
fictional31m
Has any been able to weld a busted block with the ac cast iron welding rods? my mc rod let loose and smacked a crack/hole in the side
- DukeofDeere
fictional31m
I have only seen this happen on diesel engines but the skirt of the piston is in the pan and the crown is welded inside the bore wrist pin pulled though the piston and of course crashed into the block I dunno if the blow out in the block is repairable[/img]
- DukeofDeere
Blocks are not hard to come by or that expensive, I probably have one on the shelf.
