420 crawler fresh in for parts
Post by Lavoy » Sat Jul 14, 2012 2:14 pm
Just got in a 420 crawler for parts. Several of you have been asking for some parts I was out of, but now I have them in stock.
The crawler is a 1957 5 roller, 5 speed crawler. Appears to have 10 recent rollers under it, so I now have rollers in stock again. Crawler has excellent fenders, and new repro battery sheetmetal on it. Hood is good, grille is junk.
10" track pads on decent rails, but pins and bushings worn. Engine runs good, will be out of the crawler by next week.
I also got a set of counterweight brackets and a full weight set, I know someone had contacted me about weights in the past, but I was out.
Anything you need, call or e-mail, and I will check on it.
Steven Walters
parts
Post by Steven Walters » Sun Jul 15, 2012 8:46 am
I'll take the fenders and hood.
Post by Lavoy » Sun Jul 15, 2012 11:06 am
Replied to your PM a little bit ago.
Post by Lavoy » Sun Jul 15, 2012 11:14 am
Got the crawler mostly down last night.
All 10 bottom rollers have been replaced and are like new. Sprockets are decent, no where near new, but would run a long time. Front idlers, brackets and springs are good, bushings and shafts appear to be worn. Final cases are good, and are the later style case with the bump on the pinion shaft area.
Battery sheetmetal is new, and recently installed. Has new seat cushions, seat frame is pretty good, base is perfect, slide is garbage.
Thanks for all the inquiries, I will respond to e-mails and PM's as I get farther into the crawler.
Post by Lavoy » Wed Jul 18, 2012 8:00 pm
Fenders are sold, thanks.
The engine is now available again, buyer decided to try and rebuild his own instead, so no longer wants it.
Post by Lavoy » Sat Jul 21, 2012 8:56 pm
Trackframes, rollers and rockguards sold, thanks.
jdcollector
Post by jdcollector » Thu Jul 26, 2012 10:17 pm
Do you happen to have a set of good fenders off of it or a 4 spool valve?
Patrick Thomson
440 ICD w/ 831 Loader
420C w/ 62 Blade
Post by Lavoy » Fri Jul 27, 2012 9:44 am
Fenders are sold, no hyd on this crawler, sorry.
jdcollector
Post by jdcollector » Fri Jul 27, 2012 7:16 pm
CRUD... if anyone out there has a set of fenders or a 4 spool valve for a 420C let me know. Thanks!
Patrick Thomson
420C w/ 62 Blade
sandman
Engine or engine Block , I have a cracked cyl, 420c late
Post by sandman » Fri Aug 31, 2012 6:38 am
585-771-7936
scotty
Post by scotty » Thu Sep 20, 2012 5:47 am
Hi Lavoy , we are still looking for 1st gear for a 1957 5 rollor 420, if you have one that is in real good shape let me know. Thanks Randy
Post by Lavoy » Thu Sep 20, 2012 8:40 am
Randy,
Need to know 4 or 5 speed, and serial number. Shoot me an e-mail with the details and I will check.
bitcoder
JD440 transmission
Post by bitcoder » Tue Oct 02, 2012 4:30 pm
I need a transmission for 440 gasser, preferably 5-speed with reverser.
Post by Lavoy » Wed Oct 03, 2012 9:23 am
What serial number or is it large or small transmission?
rick22
Gas Tank
Post by rick22 » Sat Nov 03, 2012 1:43 pm
looking for a gas tank. Can you email me at rrivera@hydro.mb.ca.
thanks
Rick
