Does anyone know if there's a way to pre-prime the oil in a JD 350B diesel engine before starting it? I have a 350B that's sat for 20+ years. It's now pretty much ready to start, but I'd like to pre-prime the engine oil so I don't start it dry. Thank you.
Marc
350B Diesel engine oil priming
Thank you. This is what I had thought to do, but was hoping there was a better way - like the remove the distributor and turn the oil pump with a drill like you can do on gas automobile engines. I looked at the manuals and didn't see a good way - the other thing I thought of was to pump the oil into the port for the pressure sender when I change the oil before I start it.
if you can rig up a pressure pot with oil and pull the oil pressure switch and give her an IV that is the best but if you pull the wire off the pump and crank as said above ... and spray some WD40 directly into intake as cranking
JWB Contracting
Oil priming
My dad uses a 12volt hydraulic unit and pumps oil in thru the oil pressure sender gallery. If you remove the valve cover you known the motor is lubricated when you get oil coming out of the valve train.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
