steering clutches
Eric.MacLeod
steering clutches
Post by Eric.MacLeod » Mon Apr 21, 2008 9:15 pm
im getting ready to take my 58/420 dozer apart it will not turn left or right can someone please give me a rough guess on a complete clutch set for both sides. i would like to put all new in it since it will be apart.. thank you Eric...
Post by Lavoy » Tue Apr 22, 2008 8:01 am
The fibers and steels run $224 per side. If you do pressure plate, brake band, and throwout bearing as well, then $524/side.
jeff Kemp
Post by jeff Kemp » Tue Apr 22, 2008 11:30 am
I recommend replacing at least the fiber discs and the pressure plates and at the seals while you got it apart. If the seals leak then the fibers will get oil covered and you will have wasted your time and money. Might as well check the bearings while it is apart. If they are sloppy then you will tear up the gears and then you're talking big bucks. It seems like a lot of money but it will last you forever if you do it right.
Eric.MacLeod
thanks
Post by Eric.MacLeod » Wed Apr 23, 2008 2:24 pm
getting ready to pull it apart, i will check bearings also, Lavoy i will get a list ready i would like to get tach cable and maybe one spocket if still any left , i will pull and see what i find thanks Eric
Post by Lavoy » Wed Apr 23, 2008 8:25 pm
No problem, just send me an e-mail. I will be gone for the rest of the week with no e-mail. Might be able to get on the board though.
Users browsing this forum: Google [Bot] and 5 guests
