input shaft
- Eric.MacLeod
input shaft
lavoy do you have a input shaft for a 1957 420? serail# 111376 fine spline.. trans is broke ,got spare trans,but spline was coures would,nt fit thank you
- Eric.MacLeod
input shaft
it is a four speed trans,
- Eric.MacLeod
input shaft
lavoy can you e mail the price of the shaft to me? also the man that owns the dozer is wondering if he could cut two couplers to make make one,he says his is fine and if he could get a course one he would cut it and weld it back together, he says this coupler is between the trans and clutch driveshaft, thanks for your time...Eric
It sounds like he is talking about cutting a fine spline and a course spline coupler apart and welding half of a fine spline to a half of a course spline together so he can use the course spline imput shaft that he has with the fine spline driveshaft in the crawler.
Might work IF alligned correctly.
Chuck
Chuck
Users browsing this forum: sweeperman and 11 guests
