420c governor worn?
- jdjohng
420c governor worn?
Is the pictured damage something of concern or should it be considered normal? The brass washer that goes between the block and the governor shaft is pretty worn could that be causing the wear on the timing gear and timing gear cover? Thanks for any input.
- jdjohng
Yes Lavoy The weights are kind of wobbly and the brass thrust washer is worn out. I have decided not to put it back together without rebuilding/replacing the governor. Is there a rebuild kit available from you for this governor? If so I will add it to my list of parts I will be getting from you soon. Thanks.
On another subject.... I was wondering if you have ever seen the oil supply line for the valve train get plugged or restricted? I took the valve cover off to adjust the valves and it looks pretty dry in there. Thanks again.
No kits available that I know of, I guess I have neer even checked to see if individual parts are available. I usually keep a thrust washer on hand.
I have never seen the oil line plug, but I have had the rear cam bushing installed wrong which prevents the oil from getting to the head, and also starves the rear cam bushing for oil as well. One other possibility is that the cup pluc in the back of the block has been seated too deep and is covering the oil hole to the oil line. Take the line off and start the engine, it sometimes take a few seconds for the oil to come out, but it is not a real flow.
In case your are wondering how I know this, yes I did find out the hard way on an engine years ago.
- DiggerLarry
- Contact:
Users browsing this forum: No registered users and 81 guests
