Paint
Paint
I am beginning the paint phase on some of my parts to my 440 loader.
Can anyone tell me if the Tractor Restoration paint that is sold at
Tractor Supply is the same color as the JD Industrial yellow?
Also, can anyone tell me if there is a trick to removing the cylinder sleeves on a 2-53?
Thanks Craig
Thanks Craig
Craig,
No, the tractor supply paint is the modern color. The early industrial yellow has more orange in it. Just go to mother Deere and get it. They call it "Old Construction Yellow Paint" It is the correct color for pre Nov 1 1992 equipment. the # for the spray can is TY25679 and the Gallon is TY24354. If I remember correctly the gallon was somewhere around $50.
Hope this helps.
Chuck
Hope this helps.
Chuck
Has anyone ever used the Old Construction Yellow from Deere? I bought some spray cans and not only were they expensive as hell, the paint would run off if you didn't spend 2 weeks applying 29 dust coats, and when it was actually on there it would just chip off when it got bumped with something.
I gave up on it and took a clutch housing cover (with the new paint) to get real oil paint mixed up in that color. Actually, they screwed it up 2 times and I ended up adjusting the color myself, but damn is it awesome paint.
Do I have the right color? (Instrument panel, top of transmission and seat frame are from JD spray can and clutch and final drive housings are oil paint)
Looks like you are coming along fine and have a nice crawler to work with. To my eye, your new paint looks a little more orange than the John Deere color but with the difference variations in color balance in digital photographs and computer monitors it is hard to know.
I am not a restoration perfectionist since I use my crawlers and they are lucky to get paint at all. I have started to use Tractor Supply's "Transport Yellow”. It is cheap and so am I. I would send you $10 for the paint if you would run an experiment for me. If you have a Tractor Supply handy, would you buy a spray can of Transport Yellow and try it on a surface near the correct John Deere paint and take a picture?
Most all of the JD440's I have had were repainted at some point. When I chipped off the repaint, the Transport Yellow seemed to be a pretty close match. With fading and aging it is hard to tell.
Users browsing this forum: No registered users and 28 guests
