lavoy or anyone else
switchhappy
Post by switchhappy » Wed Mar 04, 2009 7:45 pm
hay lavoy or any one else, im needing the wear plates that go on the bottom of the front idlers on a 440icd, mine has wore all the way into the bolt holes of the bolts, im talking about the wear plates that hold the idler to the track frame that bolt on with 2 bolts, im also needing the rubber elbo that goes from the blower to the air can.. if some one could make this or has it, just shoot me a price and ill let u know if i can get them... thanks
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
Post by Lavoy » Wed Mar 04, 2009 9:00 pm
I am out, but they are easily built up with weld if there is enough left to weld to.
switchhappy
Post by switchhappy » Thu Mar 05, 2009 7:10 am
well there is enought to build up on 3 of them, but the one is wore all the way to the bolt holes... so i cant weld that one up, does anyone have these or know were ic an get them?? and what do they run price wise
